My old ME66 and my vintage Shure SM58 both work well going straight into the XLR on the DVX. Likewise with Samson and Sennheiser wireless setups using the appropriate adaptors.
Needed a cheap lav for a quick sitdown interview and picked up an AT3350is with a 3.5mm mini plug output.
Going througha mini to XLR adaptor into the DVX I get nothing! Zip, zero. It does work with an old Walkman pro tape recorder with it's buil in 20db pad.
Yes, all the settings are correct: mic battey installed correctly, power switch on and camera settings ok, phantom power off on both channels.
I know the adaptor is good, because I connected the dynamic SM58 with an XLR to mini adaptor and plugged that into the adaptor on the camera...even with the reverse adaptors, the sound is fine at a good recording level.
The DVX has -50 and -60db mic input settings and no apparent way to disable them in menu.
Do these cheap "powered condenser" mics need more pre-amp than the DVX provides?
Thanks for any info.
Ken
Ken
