So I spent 2 days importing a LOT of files into Avid. They are QuickTime files (generated by Cineform) and they have a 1440x1080 aspect ratio. That's because they were HDV files, and I selected "keep source aspect ratio" when I created those QuickTime files.
I created a 1080p project in AVid to import those files. The QuickTime files themselves were no longer "HDV" after I put them through Cineform (they have been converted to QT HD files with a true 23.98 frame rate now using pulldown), so that's why I chose the 1080p/23.98 project in Avid. There are no project types within Avid that allow for HDV/23.98fps. But the QT files ARE still 1440x1080.
So when I now look more carefully at the imported files inside Avid, and select 16x9 for the viewer, the image is a bit distorted. It looks like it has been stretched a bit vertically.
Does this mean I have to edit the entire project slightly distorted? Is there another solution to view this 1440x1080 footage? Where did I go wrong? Maybe I set up the project incorrectly. I'll have to export my project with a corrected "aspect ratio" right? I've never had to do this before.
EDIT: Maybe I'm wrong here. I'm a bit bug-eyed, as I've been staying up until 3 am the past 5 nights to work on this project. Maybe the footage is not stretched? But I'm getting the sinking feeling it is.
