Re: ASA rating for the DVX 100
This is the method I learned in Electronic Cinematography at the Maine Photographic Workshop. The course was taught by Peter Fasciano. You might recognize his name from the ASC article reviewing the DVX. The following is from the course book.
Step 1
Set up a standard chip chart. Make sure the chart is evenly illuminated across the entire frame. The chart, lens and lights should all be at the same level.
Step 2
Verify the incident illumination level across the surface of the chart.
Step 3
The camera should be white balanced, the focal length set to fill the frame with the chip chart, and its aperture set manually to provide a video level of 90 to 100 IRE units on the waveform from the brightest chip.
If you don’t have a waveform I set the iris until there is no 100 zebra pattern on the white chips.
Step 4
The shutter speed on the light meter should be set to 1/30 of a second. Video cameras take 30 frames per second. Since they normally have no shutters like film cameras, the exposure time and frame rate are the same. Read the aperture setting on the camera. The ISO dial on your meter should be set so the aperture reading of the meter matches the lens.
This is the method I have always used to get an ASA setting for non 24p cameras. Give it a try. I will be soon and I will let everyone know my results. When this was written, video cameras did not have variable speed shutters. So, that may change things a bit.
Step 1
Step 2
Step 3
Step 4
