I am curious to what ASA/ISO one would rate there light meter to compare that of which the DVX absorbs light? For instance, if the amount of light it renders is as sensitive as 320 ASA film stock or is it as sensitive as 500 speed. My light meter tests are reading at 2500 ASA/ISO, even if I set my light meter at either 24fps, (which the dvx trully is not because of the pulldown) or at 30 fps. Also, I know that this is an incident light meter reading and the camera has spot meter on it, but they still should roughly read the the same, if it is not a white reflecting object.
