mattsdni
Just thought I would share what I found out this morning. I had my 1K as arri light on a shoot a few days ago and when I plugged it it the was a pop and sparks flew. It's happened a few times before too. I though I would check out the problem and try to fix it. Upon examining the power plug I found that the ground pin was not connected to anything. The power cable only has 2 wires. So it looks like I'm off to the hardware store to get some real power cable since I don't want anything catching on fire. If you have any as arri lights from ebay I would encourage you to check your power cable for the ground. Not only that, but there was an extra screw just sitting in the power plug, probably causing the shorts.
