I like the color!
Seriously, in what capacity are you looking at using this?
Get a Rode VideoMic Pro and a 20 foot cable. Bam.
I've got one ordered, and I am going to do a somewhat thorough test like I did with the NTG2 and the H4N, so when that happens I will have some numbers on how quiet it is, and some impressions on the sound quality.
Look forward to the tests. It would be great if you could plug the preamp signal directly into a camera to hear the result as well.
Thanks.
I would be concerned about over-driving the mic input on the camera. Most electronic gizmos operate best when they're operated in the middle third of their adjustment ranges. For the ART preamp, that means it will be adding between 8 and 18 db of gain to whatever the mic's native output might be. I haven't been able to locate a sensitivity spec for the 60D's external mic input but it is clearly designed for mic level and the output of the ART will be pretty hot in comparison. While it might work, it seems it would be pretty touchy to keep from overloading the input on peaks. There's a slippery slope to avoid, where you're increasing the signal strength going to the input while reducing the gain in the recording amp to avoid clipping. Eventually you get to a point where a hot signal going in overloads the input circuits before the gain control has a chance to affect it. The result is you're recording unclipped distortion. To avoid this you may find that you're running the ART on the bottom couple of notches on its gain control, so why bother with it at all.
