Tim Naylor
Put both together last night with Zacuto rod system. Subrented a chosziel (again) as one day a stork may drop my RR mbox down the chimney. Dialed everything in last night and did my first gig with them this morning.
They make a wonderful team. Sharpest pro-sumer with the sharpest adaptor. First thing that wowed me when setting up the Ultimate was the back focus function. With the EX1's colored peaking and the Ultimate's back focus ring, getting this dialed in was a breese. Letus was also thoughtful enough to include a real manuel. Yes, it's true. A bonafide hard copy that fits nicely into my camera bag - with a Siemen's chart on the back page. Bold and long overdue move.
Had a few minor hardware issues that Hien is taking care of asap, mainly concerning the fit of the rod / bracket. At full extension, my Chrosiel still couldn't get dead center. The Chrosziel is at a standard height and the centering was off by 1/4". Not a big deal with a 17mm, but a 14mm may run into vignetting issues. Hien is working on a fix.
Other big deals about the Ultimate. The image is stoopid sharp! Haven't seen anything like it. Smart move to use a belt drive for the GG platter as not only does this help isolate superflous vibrations but makes replacement a breeze too. Optically it gets rid of the pulsing that's endemic with other spinners. It's also mounted on two ball bearings not one. This maintains a true right angle. My previous spinner went back to the shop twice because it would lose true and induce the wobbles. Not pretty as it eventually goes so out of wack that it lead to complete platter failure. It couldn't safely say it wouldn't fail inside of a week. Too nerve wracking.
The RPM indicator is quite welcome. At the end of seven hours it said low battery. Nice touch. Comes with a D mount power option - which I hope implies a relay lets down the road for 3/4" cameras.
Back to the picture. With the EX1's monitor, I didn't feel the need to lug around an onboard monitor. Granted it would be better but this was a a three man crew doc /PSA project where we had to trek the length of Manhattan getting beauty shot after beauty shot. I'll have images from the project up in about three weeks after the PSA is released. Until then just take my word as best you can.
Is the Ultimate worth 4500.00? I'm leaning towards yes, but this is just day one. By the end of this project on monday, I go to New Orleans to use it on another film. By then I'll know how well it performs in the beauty B Roll realm. Then I'll be shooting a short that'll cue me into it's narrative virtues. As Beauty B Roll is not focus que heavy, I've yet to see how the whole lens mount / back focus system holds up to the focus heavy/ hand held demanding world of fiction.
The bokeh with the Nikon glass I'm using is quite gorgeous. It's a nice balance in terms of preserving light sensitivity. We stole some shots shooting into Tiffany's at 2.8, -3db and still got a full signal. It's a world sharper than my LEX and I loved the way that looked. It's bokeh isn't quite like my SG's but the build, sharpness, and lack of grain and artifacts are in a class by itself. I'd compare it directly to the PS technik. No edge to edge issues. It's workmanship is good but not quite up to to PS standards - but what do you expect at 1/4 of the price. I'd put the optical quality in the same league though.
I'd like to see all the adaptor makers really put some money and machining into the rod mount bracket. This can't be flimsy in any shape or form. This is the piece of gear that protects adaptor and camera from the everyday g forces and knocks a camera system endures through out a production day. It should be a heavy duty ring encircling the entire adaptor like a high quality lens support you see on cine lenses. Not that I'm careless with gear but we swing cameras around all day long. I never worry about the mount on an ENG camera or an Arri. But I do worry about the security of the way most 35mm adaptors attach to a camera. A heavy duty circular mount with complete vertical adjustment and well machined 15 or 19mm holes/locks, is the minimum. For God sakes people are hanging 2-3lbs zooms on these things. The thread of the camera, set screws and 1/4 inch screw through the bracket to adaptor isn't enough. Right now, rod brackets seem like afterthoughts when they should be the root of you lens mount rigidity. Without a bracket on, despite how good your PL mount is, the system becomes too rickety for focus and you run the risk of shearing the adaptor off your camera should it take a knock. So the lens mount chain really starts at the bracket and like any chain, it's as strong as the weakest link.
The Ulimate's bracket is the most solid I've seen from the low cost adaptors but it's still not enough. If there were a place to overbuild it's the hardware that secures the adptor to rods.
So that's Day 1 it the Ultimate.
Oh, how'd I dig the EX1? Love it. CMOS artifacts were not a factor - yet. Color palette is a little thinner than my HVX but overall I like it better so far for what I'm doing on this job. The monitor and speed/shutter options blow away the HVX as well as the lens. However, this is all Phil Bloom style stuff so I haven't tested the narrative / hand held. So I've yet to see the ugly side of CMOS, unless I try to force the issue (panning back and forth against a picket fence, etc). What I don't like is that the monitor cannot flip to a right angle of the camera axis (the AC's position). Now the AC and I have to cozy up as with the HVX I can use the eyepiece and the AC could stand off to the side with the monitor positioned looking off camera axis. Very convenient.
Will I sell the HVX and go EX1? Will know in a week's time.
Tim Naylor - DP
www.timnaylor.com
Tim Naylor - DP
www.timnaylor.com
