Used this on one shoot. Still in new condition. No need for it any more. If interested call 949.388.9308
Specs:
The Arri Softbank D2 Three-Light Kit was designed with modern, light-sensitive digital media in mind, so you can accomplish even more than you might think with the 1250 total watts in this package. Two of Arri's most popular Fresnel lights form the core of this complete lighting outfit: two of the very efficient 300W Plus Fresnels each use a 3.2" (80 mm) low expansion, borosilicate Fresnel lens to produce a soft, even field of light. The 650W Fresnel features a 4.3" (110 mm) lens with the same reflector, housing and power cord as the 300W Fresnel, producing (of course) more light. A Chimera 16 x 22" softbox is included (perfect for interviews and soft light in tight spaces), as well as barndoors, filter frames, light stands, bulbs, a ceiling scissor clamp to hang a fixture from a drop ceiling, and a hard compact carrying case for storage and transport. This kit is equipped for 120V AC operation. It will also function with 220-240 AC Voltage, with the appropriate bulb and plug adapter, available separately.
Fixtures
Light Spread
Fresnel fixtures produce a soft, even field of light
Lenses
# The Arri 650 has a 4.3" (110 mm) low expansion, borosilicate Fresnel lens
# The Arri 300 Plus has a similar lens, measuring 3.2" (80 mm)
Ventilated Housings
Ribbed for cooler operation, the fixture ribs act like heat sinks to help disperse any heat build-up
Aluminum Reflectors
Spherical, specular, high purity reflectors
Light Shapers
16 x 22" Softbox with Adapter
Chimera Video Pro Softbox provides varying degrees of softness, with a removable front diffuser
Barndoors, Scrims, and Filter Frames
Enable adjustments of the fixture's light spread, intensity and color
Support and Storage
Drop-Ceiling Clamp
# For mounting a 300 Fresnel from a drop ceiling frame
# It features a standard 5/8" (baby) mounting stud
Compact Kit Case
# Vacuum Molded ABS Plastic Case
# Butterfly Latches and Reinforced Piano Hinge
# Spring-loaded Side and Top Handles
Specs:
Fixtures
Light Spread
Lenses
Ventilated Housings
Aluminum Reflectors
Light Shapers
Support and Storage
Drop-Ceiling Clamp
Compact Kit Case
