The MFF-1 is a lightweight, single-sided follow focus from ARRI. It is fully adjustable, which allows the unit to be mounted to any camera system with 15 mm lightweight support rods. It can also be supported from 15 mm or 19 mm bridgeplates using standard adapters.
+ Unique space-saving snap-on bridge mechanism
+ Plunger mechanism that engages adjustable, hard stops for lenses with infinite rotation
+ Reversing feature for Nikon and Leica lenses
+ Compatible with ARRI driver gears and knob accessories
The marking disk is beveled for easy viewing of marks over a wide angle, and handwheel can be adjusted vertically for hard to reach setups and support in handheld operation. The focus ring can be set to rotate infinitely, as in a standard unit, or with adjustable hard mechanical stops to limit the focus range. The follow drive unit can also be flipped so that it rotates in the opposite direction. The handwheel accepts standard Arri focus whips and cranks and uses standard Arri focus gears on either side to best fit your lenses.
Because it is so highly adjustable, with an optional 15mm – 19mm rod adapter (AB-1519), the MMF-1 is compatible with virtually all full-sized HD cameras, RED One and film cameras.
In great shape! Used a handful of times. Comes with focus whip.
ASKING $825.00
email me direct at chrismail3209@gmail.com or private message me here
ASKING $825.00
