$3750. Local Los Angeles Only. >$600 Retail Value
Brand New. Moved up from DSLR to Red and cannot use.
The MBP-1 is designed especially for handheld HD camcorders with smaller profiles. It is the first of it's kind by ARRI.
Vertical and horizontal adjustable centering mechanism to compensate for variations in camera base to optical axis measurements
Fits Sony EX-1, Sony EX-3 and Panasonic HVX-200 cameras
Also compatible with Canon HDSLR cameras when used with Arri's Canon 5D Riser or battery grip
Fully compatible with ARRI 15mm lightweight support rod standard
The Arri 5d riser plate is designed to be used in combination with the Arri MBP-1 Base Plate in order to raise your HDSLR to the correct height when using a Mattebox.
Don't be seduced by Zacuto and other bulls*%t. This stuff is the best. Rods not included.
