Viddovation
This kit includes:
3 - 650 Watt 120 Volt Arrilites (571065)
3 - Barndoors (571110)
3 - 7-1/4" Full Single Scrims (571150)
3 - 7-1/4" Full Double Scrims (571152)
3 - FAD 650 Watt 120 Volt Lamps (571140)
2 - AS-01 Lightstands (5710051)
1 - Photoflex Compact Lightstand (replacement for an AS-01)
1 - Compact Three Light Case 32-1/2" x 17" x 10-1/2" (571194)
Sells new from Adorama for over $1500.
Two heads have cracked outer casing, doesn't effect performance.
One head has a worn outer cord casing at the head, and is missing threading to connect to the light stand (meaning, it won't currently lock tight on the stand). The replacement part is L4.77145.E - http://www.filmandvideolighting.com/16stso5bastb.html
All three lights fire and work fine. As noted above, 3 bulbs are included. Bulbs are used, remaining life not guaranteed.
Kit is located in Nashville, TN.
Asking $1,000.
Asking $1,000.
