The Quote below is from High Definition Magazine, a UK publication. On page 8 of the january issue they say...
"...Up until now the term 'progressive' indicated a kind of image capture at the chip that replicated the motion portrayal of film capture. The 'juddery look'. There was only one way to achieve this using what has been called for the past five years a progressive CCD.
There weren't too many black holes to fall down in looking at specifications of a camera that does both interlace and progressive as the spec was similar.
All of that has changed. Low cost cameras XDCAM HD and HVX 200 use an interlace chip to capture the image. If progressive mode is selected then onboard processing creates a progressive frame. The on-board processing degrades resolution and causes a delay in the viewfinder... [SNIP] ...Sony in a remarkable sign of restraint are promoting the interlace XDCAM HD f350 as a progressive recording camera, rather than as a 'progressive camcorder'.
However Panasonic are calling the interlace CCD '200' a progressive camcorder.
They are redefining the term progressive.
So now one needs to ask if the camera they are using is a 'true progressive scanning camera'. "
They seem pretty confident about all this. Is it true? Do you agree Panny are redefining 'Progressive'? and is the chip really an interlaced one?
Hoping for good natured discussion,
-Chimpan A
-Chimpan A
