Are clone batteries ok in FS700
capt chuck
I just got my FS700 (yahoo!) and it works fine with the included battery. I also have a NP-F970 clone that I've used with another camera for several years. When I try to use that one, within a minute I get a "...battery too hot, camera shutting down..." message. It doesn't seem like it would overheat that quickly and it certainly isn't the least bit warm to the touch. Do clones work on the FS700 or is there some "intelligence" in the batteries that force the use of Sony branded only? Or could there really be something wrong with this battery that my old camera doesn't detect?
For the price of the camera I would not go cheap on batteries, it's not worth the risk.
In some ways I agree with you, that is the safest route and I wouldn't go with a complete no-name. But I've had a number of third party batteries from established companies for both Sony and Panasonic over the years that have proven themselves and I trust so I am still curious if the FS700 will work with clones or not.
I had the same problem with a knock off battery. Stick with Sony!
I´m using two different no-names with the FS700. Both work fine but they weren´t cheap ones. They almost cost the same as an original 970 but have 1/3 more capacity.
... or is there some "intelligence" in the batteries ...
There is intelligence in the batteries; i.e. a micro-controller ("gas gauge") that keeps track of the battery state and monitors health, temperature, etc. In principle the clone makers should have this figured out and should be using compatible chips; but of course there's infinite scope for them to do a sloppy job. I've had issues similar to yours on another camera when using clones. So basically it's a gamble.
I bought some clones (Pearstones, which seem to be well-regarded), as well as Sony batteries; but I have lights and a monitor to use them with. Don't know how well they run on the FS700, but I'll give it a shot.
Hi there,
I've been using a third party NP-F batterie I've bought on EvilBay without any problems so far.
In fact, the voltage rating is even lower than the Sony's at full charge so it would not be a problem at all I think.
It's the 6600mAh version and I bought it from a UK vendor.
Cheers.
Thanks everyone.
May be because my battery predates the FS700 by several years - like others not a cheap clone but old enough that the new cam may pass on it. Since others have seen the same error message however, I feel like I can still safely use it on my old camera.
I've been using third party Sony batteries for years, out of the 6 or 7 I have only 2 are Sony. I'm not paying $100+ for the 970 when I can get a perfectly functioning knockoff for less than 1/2 that amount. I originally bought a couple generics to power lights and a SmallHD monitor and when I bought the FS100 the original owner included a couple generics. I've never had any issues - going back more than 10 years to a Z7u, Z1u and even a PD150 - and don't hesitate for a second using them. I have one that doesn't register the battery meter on the camera or charger - but still powers the camera with no issues - so I use that one on my light, the rest are fine.
I just had a very interesting experience with the Sony vs. the clone (in this case Vivitar batteries). I bought the Sony 970 batteries from mellowdigital.com. They pull a bait an switch and afterwards I found 58 out of 64 "one star" ratings, many with the bait an switch comments on http://www.resellerratings.com/store/MelloDigital. They actually show the Sony battery but then call and say it will be a couple of weeks and Vivitar is a brand name and the batteries or equal to Sony that can go out today. So here are my results after checking the 970s (6,300 Ah for Sony but Vivitar rates their batteries at 7,400 Ah) against and actual Sony NP F770 (4,200 Ah) which is a smaller battery:
a) All three batteries charged on the same Sony battery charger (AC - VL1) until the charge light went off.
b) Executed on a Sony FS700 with no record time - the camera framed the same shot static the whole time.
[TABLE="width: 287"]
[TR]
[TD]Sony[/TD]
[TD]Time[/TD]
[TD]Elapsed[/TD]
[TD]percent[/TD]
[/TR]
[TR]
[TD]LP F770[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]8/17/2012[/TD]
[TD]10:43 AM[/TD]
[TD]0:00:00[/TD]
[TD]100%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]11:18 AM[/TD]
[TD]0:35:00[/TD]
[TD]83%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]11:46 AM[/TD]
[TD]1:03:00[/TD]
[TD]68%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]12:11 PM[/TD]
[TD]1:28:00[/TD]
[TD]53%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]12:23 PM[/TD]
[TD]1:40:00[/TD]
[TD]47%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]12:37 PM[/TD]
[TD]1:54:00[/TD]
[TD]39%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]1:11 PM[/TD]
[TD]2:28:00[/TD]
[TD]20%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]1:27 PM[/TD]
[TD]2:44:00[/TD]
[TD]10%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]1:48 PM[/TD]
[TD]3:05:00[/TD]
[TD]0%[/TD]
[/TR]
[/TABLE]
Note: this battery tracked 1 percent at a time down to 0% and I was able to turn the camera off, it did not power down by itself. I've seen enough comments about the camera shutting down in the middle of a scene and corrupt files to know it is much better to shut down uninterrupted - definitely a "no no".
1[SUP]st[/SUP] Vivitar Battery test
[TABLE="width: 280"]
[TR]
[TD]Vivitar[/TD]
[TD]1:49 PM[/TD]
[TD]0:00:00[/TD]
[TD]98%[/TD]
[/TR]
[TR]
[TD]SB F970[/TD]
[TD]2:22 PM[/TD]
[TD]0:33:00[/TD]
[TD]93%[/TD]
[/TR]
[TR]
[TD]8/17/2012[/TD]
[TD]2:50 PM[/TD]
[TD]1:01:00[/TD]
[TD]89%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]3:35 PM[/TD]
[TD]1:46:00[/TD]
[TD]83%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]4:33 PM[/TD]
[TD]2:44:00[/TD]
[TD]75%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]6:01 PM[/TD]
[TD]4:12:00[/TD]
[TD]0%[/TD]
[/TR]
[/TABLE]
Camera completely stopped while gone - so the 4 hours is inaccurate
2nd test - different battery from 1st test
[TR]
[TD]Vivitar[/TD]
[TD]11:39 AM[/TD]
[TD]0:00:00[/TD]
[TD]99%[/TD]
[/TR]
[TR]
[TD]SB F970[/TD]
[TD]12:13 PM[/TD]
[TD]0:34:00[/TD]
[TD]95%[/TD]
[/TR]
[TR]
[TD]8/18/2012[/TD]
[TD]12:37 PM[/TD]
[TD]0:58:00[/TD]
[TD]91%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]1:43 PM[/TD]
[TD]2:04:00[/TD]
[TD]82%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]2:26 PM[/TD]
[TD]2:47:00[/TD]
[TD]76%[/TD]
[/TR]
[TR]
[TD][/TD]
[TD]3:03 PM[/TD]
[TD]3:24:00[/TD]
[TD]0%[/TD]
[/TR]
[/TABLE]
NOTE: dropped off from 76% to 0% in 37 minutes – it may have been less. This is just when I happened to look at the battery’s progress
This is close to the one above so Vivitar battery #1 test probably dropped to zero at about 3.5 hrs as well
Difference in time between Vivitar and Sony smaller battery is 19 minutes. Also the drop happens very fast on the Vivitar and the Sony goes slowly down to 0% on the battery read out.
Hope that helps.
Regards,
Michael
Yes - same experience here. With the clones, don't believe the drop in actual charge - and hence the remaining time - will be proportional to the readout; I'm getting 100% for what seems like ages - only to go down to zero in no time at all (and usually, the camera just switches off by itself).
Also, the batteries take ages to achieve 100% charge - i.e. before the light goes green on the charger. Since they are "brand" names (Zoom and and Swit), I guess some part of the Sony's intelligence is still their sweat secret...
So to answer the OP's question: if they work at all, they are just what the question suggests: OK :)
Thanks, that sums it up pretty well.
And thanks mikem33 for the details regarding the falloff.
I bout three no-name NP-F970s from a German retailer on recommendation.
Their performance seems up there with my Sony branded battery.
However.... charging the little suckers is a different story. The supplied NP-F charger 'trickle charged' them taking over a day to get full charge. I bought a Sony Dual Gang charger off Amazon and this charges them quicker, but nothing like my EX1's BP-U charger which does a BP-u60 to full in 4 hours. It still needs 12-18 hours to charge a couple of my no-name NP-Fs. I had a couple of cheap chargers too, used them abroad and the chargers expired.
No-names are fine if you have low expectations or a camera like the FS100 that will sip on an NP-F970 for a whole day.
In the grand scheme of things, I think I'll go Sony in the future. I'll keep my no-names as a backup or for my LED lamps, but the £50-70 I saved per battery ages ago isn't quite stacking up to the value of being forced to wake up in the middle of the night to swap batts on the charger, or the doubling up of batteries (and weight) to get things working on the shoot next day.
I fought the law... and the law won. :)
Just tried my Pearstone 770 on the FS700... it basically worked like a charm, except the battery gauge dropped VERY slowly. Until I powered the camera off and took it home... then I got a BIG drop. I didn't actually measure the capacity, but it seemed fine, just that the displayed charge was wonky.
So I think I'm with the consensus -- stick with Sony batteries for capacity, correct gauging, and charging; the third parties all seem to fall down on at least one of those.
To shed light of the battery gauge performance - basically there are two ways to make them. Sony, Panasonic (also Anton Bauer) use a real "Fuel Gauge" smart circuit, where the charge is metered going in during charge, and then going out while discharging - powering a camera. This is the most honest to goodness and more expensive way to do it. The state of charge is displayed accurately regardless of how much power is being used by the camera. The generic battery manufacturers use a much more simple voltage based method, trying to estimate the state of charge while measuring the battery voltage with a simple voltmeter like internal circuit. This is never accurate as the voltage will be influenced by temperature, power draw etc. This method is good enough only to tell a fully charged battery from a mostly discharged one.
As far as how fast the full charge is achieved, Sony and other brand name chargers look at the battery while charging, and if they suspect it to be a generic, slow down charge rate to be on the safe side. The cheap generic chargers charge slowly as they just do not have the horse power to do it fast.
Thank you Alex. You have illustrated it beautifully. And therein lies the rub. I am annoyed to the Nth degree about this slow-down of the charge rate, and I'm sure their legal and marketing departments can make up good reasons why this is so, but it sucks very big dense things through very narrow gaps. For me, I spit in their direction and proclaim that they win. Didn't say I'd be nice about it.
But then again, I'm moving to V-Locks.
Hi Alex! Did you have an opportunity to check the weird SWIT battery behavior I asked you about? I guess if you don't explain it to me, no one will :)
Hello Piotr, thank you for reminding me. The new SWIT battery that I just tested does not have any issues as you described to me earlier. The LEDs work just fine when the button is depressed. But you are not imagining - I have a Panasonic version of the same battery here that has somewhat of a similar issue. The LEDs are flaky. Try to get yours replaced where you purchased it. Best regards.
Matt, it is a worldwide conspiracy. They all want you to buy one of our fast chargers :-)
