cheezweezl
One of my best clients just made the decision to stick with EX and the Letus until the DSLR's get up to speed. However they're also buying a 7D in the meantime.
my plan as well....
By diffused he didn't mean the look you get using a diffusion filter. He was talking about how the 35mm adpaters that use a more diffused ground glass render a better filmic image.. like for example, Dillons work in this thread : http://www.dvxuser.com/V6/showthread.php?t=187839 , arguably rivals what you can get from any vdslr.
You can still get that look with cheaper solutions on a full frame sensor. The reason it resolves that way is because the light is being diffused ever so slightly. The other effects you are seeing are the shallow DoF, the good lighting and comp, and the color manipulation from post.
If they resolved the aliasing issue and audio issue we would not even be having this discussion. How long will it take before somebody does come up with a camera which solves these issues? I give it a year at most.
We'll find out in two days.How long will it take before somebody does come up with a camera which solves these issues?
