SOLD Aputure COB 120T 'Hard light' LED with Bowens Mount - UK/EU sale
Status
Not open for further replies.
Ben Scott
I have used it twice so in excellent condition.
3000K Color Temperature
Bowens Mount
18db Quiet Fan
Wired Remote Controller Box
Wireless Remote with 328' Range
V-Mount Battery Plate on other side of controller
Built-In Handle
Carry case
he Light Storm LS C120t LED Light with V-Mount from Aputure is a chip-on-board (COB) design fixture with a 3000K color temperature. The result of this technology is extremely accurate color rendering of 97+ CRI and a 97+ TLCI (Television Lighting Consistency Index) rating.
The LS C120t can be seen but not heard: ideal for sound sensitive environments. The intelligent cooling system employs temperature sensitive fans to regulate the heat. There's also an auto/force button that triggers maximum cooling. In any case, even at maximum power, the fan noise doesn't exceed 18dB: basically the sound of a person breathing.The LS C120t's performance is backed up by its design. The all-aluminum construction goes through over a hundred fabrication steps. The reflector and accessory mount is the widely used Bowens S-type, and the wired controller is also separated from the body of the light, making it lighter and reducing its size. There's also an included wireless remote that allows you to control on/off and dimming functions from as far away as 328'. The LS C120t is ready for worldwide use thanks to its 110-240 VAC power supply. You can also use its onboard V-mount battery plate for external battery power when mains power is unavailable.
I've just bought the daylight version so gonna offload this one to save space. Great LED 'hard' light and works with all the inexpensive bowens mount modifiers like softboxes and fresnels and octodomes and shizz.
https://www.youtube.com/watch?v=x2oDyeAc7x0
And I used it as the backlighting spotlight on this
https://www.youtube.com/watch?v=ZaOxwlqiERM
£380 posted to mainland UK
£400 posted to mainland EU
Status
