Apple ProRes compression rates regarding future A7s 4K external workflow...questions
As we wait for Atomos to release it's much anticipated Shogun for cameras like the Sony A7s, does anyone know how many types of Apple Pro Res codecs the Atomos Shogun will feature?
For example: on page 19 of the Apple ProRes white paper, Apple states lists the following Pro Res compression rates:
https://www.apple.com/euro/finalcutpro/docs/Apple_ProRes_White_Paper_October_2012.pdf
UHD
ProRes 422 Proxy: 145 Mbps, 65 GB/hr
Pro Res 422 LT: 328 Mbps, 148 GB/hr
Pro Res 422: 471 Mbps, 212 GB/hr
Pro Res 422 HQ: 707 Mbps, 318 GB/hr
Cinema 4K (if we eventually do get some kind of "Cinema 4K" addition in a future A7s firmware upgrade):
ProRes 422 Proxy: 155 Mbps, 70 GB/hr
Pro Res 422 LT: 350 Mbps, 157 GB/hr
Pro Res 422: 503 Mbps, 226 GB/hr
Pro Res 422 HQ: 754 Mbps, 339 GB/hr
Would all of these different flavors of Apple Pro Res be available on the Shogun, or only Pro Res and Pro Res HQ?
My reason for asking is that it would be great to have a 4K Apple Pro Res codec close to the efficiency of Panasonic's "4K 100 Mbps".
Would that be the promise of the much anticipated future H265 codec?
Thanks for replying atarijedi. I'm hoping they include a 4K codec that's as close to 100 Mbps as possible. Coming from a Canon 1DC background, I never liked the enormous file sizes that came with 500 Mbps. If I can't get 100 Mbps, I suppose 328 Mbps would be the next best thing, more efficient that 500 Mbps in any case.
But it would be very interesting to see if some sort of highly efficient 4K H265 codec became available as as additional choice.
You really can't compare ProRes to H.264 (as used in the GH4). H.264 is a much more sophisticated codec, getting a much higher compression ratio for the same quality -- IF the camera does it well, which requires a lot of processing power. For example, looking at the FS700, 24 Mb/s H.264 is pretty close in quality to 200 Mb/s ProRes.
Saying that "328 Mbps would be ... more efficient that 500 Mbp" is wrong, because you're not taking picture quality into account. It's a smaller file, yes, but that doesn't make it more efficient. You could compress an hour of video into a megabyte, but it would look pretty bad.
So no, 100 Mb/s ProRes for 4k would be dreadful -- compared to using a Ninja for HD, it would be half the bitrate for 4 times as many pixels!
If you want a small file size, you need a camera which has a powerful codec like H.264 or H.265, and the camera needs to do a good job of compressing it, as well, which needs powerful hardware. Right now, AFAIK, that's just the GH4.
Thank you AtticusLake. Do we know how many types of Apple Pro Res the Atomos Shogun will feature? Will it be all four? (Proxy, LT, Pro Res, Pro Res HQ)?
I can't see that info on their web site or press releases (I assume you already checked), so I guess we'll have to wait and see.
