Apple ProRes 422 (Proxy)
Jonathan12uiz
apple prores 422 (proxy) says it's mbps is 45. I'm using the Lpowell's 40mbps gh13 settings. Shouldn't this be more than enough to edit this footage?
not the same mb/s your comparing. 40mb/s avchd would give you a bitrate of 400mb/s with prores. It all depends on the compression scheme, but your not losing anything by converting to different formats, unless of course its to another lossy format, which i dont believe prores is. Bitrate only really matters when your considering the bandwidth of your raid.
ProRes Proxy is lossy, it's designed for proxy edits. It's a highly compressed intra-frame codec as I understand it (so everything is I frames but they're compressed like JPEGS for example, throwing out data within the frame.) Bad. Use ProRes 422 or at the very least ProRes LT.
