Apex 175 Shotgun ($90 Toronto ON)
Moz
http://toronto.en.craigslist.ca/tor/pho/690828284.html
Used Apex175 shotgun mic. Has battery power or phantom. Uses standard XLR. Was used as a camera microphone, recently upgraded. Priced to sell
CAT IS NOT INCLUDED. Just the mic and the foam. You can get xlr cables for dirt cheap at active surplus.
This is the ideal microphone for sound reinforcement applications where the microphone needs to have a tight pick-up pattern, but cannot be placed close to the source. Shotgun microphones are most commonly used on sound-stages, for stage plays, for broadcast or for electronic newsgathering. This supercardioid shotgun mic will run on either phantom or battery power. The APEX175 is shipped with a "pistol grip" mic clip, and a foam windsock and is ideal for any application where a great performing, yet lightweight (392g) shotgun mic is required.
* Type: Shotgun Mic
* Element/Capsule: Back Elecret Condenser
* Operating Voltage: Battery 1.5V or 9-48VDC Phantom
* Current Drain: >2.0mA
* Output Impedance: 250 Ohms
* Frequency Range: 80-15000Hz
* Pollar Pattern: Super-Cardioid
* Sensitivity: -70dB
* S/N Ratio: >65dB
* Maximum Input SPL: 120dB
* Connector: Internal 3 pin XLR-M
* Weight: 392g
* Dimensions: 22mm x 305mm
* Included Accessories: Windsock
It's no
Sennheiser , but its still miles better than any onboard microphone.
I prefer dealing locally otherwise buyer pays shipping.
Cheers
SOLD
DVXUSER.COM Marketplace Guidelines
--If you're not interested in the item(s) for sale please do not respond or reply in the post ,,,
I payed 130 dollars for it new so I don't care what some shady site in another country sells it for.
