TheTrickster
I'm looking to further understand the use of Aperture Priority mode on the GH4 using AutoISO.
As I'm recording in changing environments (underwater), I ideally would like to fix Aperture (so my depth of field is static), I would like to fix the Shutter Speed (obviously) and so would like the camera to adjust the Gain/ISO to keep the exposure constant.
In Manual (Movie) mode you cannot set the ISO to AutoISO, so that mode is out, can't really use Shutter Priority as I need to keep the lens stopped down to around f6-f8 (as I presume it will try and set the Aperture wide open) - so my final thoughts on this are to use Aperture Priority and hope the camera is doing some voodoo to keep the shutter speed up...
From playing with the camera in Aperture Priority (Picture) mode - as movie mode doesn't show any details of shutter or iso
it does appear that it ups the ISO and keeps the shutter at 1/60 when moving to darker scenes and then in lighter scenes it increases shutter speed (when I presume its moved the ISO back to 200)
All this is guess work, as I have no idea if it definitely sacrifices ISO before shutter speed? I've read on Personal-View (from GH3 comments) that the minimum shutter speed is 1 / ( FL *2 ) the focal length but wondered if that is confirmed?
I wondered if anyone out there knew how Panasonic have programmed the GH4 for movie mode while in Aperture Priority.
Thanks!
Thanks!
