Aperture functionality with non-Sony lenses
Sorry if this has been covered. I'm new to the FS700 boards.
Just wondering how other lenses function on the FS700. Can the iris be controlled from the camera body if you are using non-Sony lenses (Nikon, Tokina, etc.)? Or do you have to use lenses that have manual aperture?
Metabones II electronic adaptor required for EF glass for Iris/IS control, no AF - otherwise manual iris w/Nikon or Tokina lenses.
It depends on the lens mount of the lens (not the manufacturer -- Tokina make lenses in multiple mounts).
With Alpha lenses, you can use the Sony LA-EA1 or LA-EA2 adapter; those adapters contain motors, controlled by the camera, to control the aperture lever on the lens -- so you use the camera's aperture knob. I've got the LA-EA1 adapter, and it works, but is very clunky -- there's a loud click every stop. So no use while filming.
With lenses that have a manual aperture ring on the lens -- Canon FD mount, Nikon non-G lenses, old Pentax lenses, etc. -- no problem, you just use the lens' aperture ring.
With Nikon G-series lenses, there's a mechanical aperture lever on the back of the lens but no aperture ring; so you need an adapter with a mechanical ring to control the aperture. Check the prices of those, they seem to be insanely expensive, to the point where I just won't buy a G-series lens.
Canon EF mount is electronic only, and the camera doesn't support the EF protocol, so you need an adapter with a computer in it which does -- like the metabones adapter. It's quite pricey though. There are cheaper adapters which have a separate iris built-in, but the iris is in the wrong place and generally causes vignetting, so I would avoid those. Basically if you own Canon glass get the metabones, but if not, I would avoid it -- EF lenses are the hardest to use on any other camera, and there are plenty of superb lenses in other lens mounts.
Nikon non-G lenses are the most versatile, as they have the longest flange distance and a built-in aperture ring.
Yeah I am not interested in Sony glass. Other than that, I am open to buying whatever lenses make sense. I own a Zeiss 50mm f/1.4 with Nikon mount, and that has aperture control on it, so should be golden there.
So what you are saying is Nikon F mount lenses, and many others out there, will require an adapter not only for the mount, but one that controls the iris. The FS700 body will only control iris for the Sony lenses, right?
Not quite -- what I'm saying is that Nikon F mount G-series lenses will require an adapter which controls the iris. Non-G F mount lenses -- such as older Nikon lenses, and your Zeiss -- have an aperture ring built in. But yes, the FS700 body can only control E-mount lenses, and Alpha-mount with limited control through the Sony adapters.
FYI FotoDiox make a Nikon incuding (G) to NEX adaptor that allows for manual control of the aperture from the adaptor. Not so expensive at $ 49.95
Works great of the FS700
cheers
Morton
Oh, thanks for that! Yes, that does look a lot more affordable than some of the others.
How is the control? As I understand it, those adapters use the stop-down lever, and only have a small range of movement, hence aren't too precise -- is that right?
Cheers!
The movement on this one is about 1/2 inch and there are no markings to know what aperture you are at. But you have stepless control over the aperture.
cheers
