Anyone using this setup...
earmarkcreative
.... for their HD edit suite?
Intel Mac Pro w/Kona 3 card -> HDSDI out -> AJA Hi5 -> HDMI out -> consumer level LCD display, 1920x1080p native rez .
Interested in finding out how this has been working for you as a low-cost monitoring solution versus, say a Panasonic 17" monitor BT-LH1700W MSRP $3400 / B&H $2499.95.
Thanks in advance!
That's my exact setup, except the lcd display is my client monitor, I use the BT-LH1700w for my edit monitor, but after setup, my lcd looks pretty close to the panasonic.
cw,
What brand of LCD monitor are you using?
I assume you're using one Kona3 HDSDI output to drive the Hi5 and the other HDSDI to drive the panny monitor?
I believe the Hi5 has a "loop-thru" as well. Are you using that?
What about a simultaneous SD feed? Are you using the down-converted output off the Kona3 for anything?
I do feed my panny monitor with the hdsdi out and a apple 30 inch cinema display mounted on the wall for clients with the other hdsdi out. I feed a downconverrted signal to an sd monitor also with the component out. Most clients want to see what the hd project will look like in sd.
