Dave,Many thanks Jay. Sounds like you and I are doing similar sorts of work.
A few further questions:
How does the GH1 footage compare with the HVX?
Do you use the 20mm Lumix pancake? If so does the in-camera mic pick up the noise from the auto focus? How about an external mounted on top of the camera (do you use the Zoom)?
Why do you use the GH1 for Broll only? Why not the interviews too?
Do you use a stabilizer?
Good to hear the AF works well in a pinch. You've certainly tweaked my interest!
Thanks!
Dave
Footage between the 2 cams can be more or less matched with some tweaking(for my purposes exact matching is not crucial), either in cam or post. I do mine in cam and it works fine. The HVX is on "cinematic b" from Barry's HVX book and the GH1 is on "smooth" with a boost in saturation and contrast.
Pancake focus is silent. Yes I use it, but honestly I use the kit and my Nikkor primes much more (28mm 2.8, 49mm 1.4) FYI I very much dislike the servo focus of the Panasonic lenses. If the auto focus didn't work so well I wouldn't use them as much.
I will probably buy an external mic eventually. I've heard good things about the Sennheiser. I probably wont ever use it for my main sound because I bought the camera for a super quick, low profile, small, high quality, alternative to the HVX. Something I can whip out and run down the road with or hike 5 miles with. I dont want to mess with external sound recording. Especially having to sync clips. Sometimes I may have 200 or more clips in one news segment's raw footage. I wouldn't want to F' with that and my editor would not be happy about it either.
I use a stabilizer that I bought from a guy in Hollyweird years ago built for the DVX. Its a simple counterbalanced shoulder rig that pretty much mimics the weight distribution of a full size broadcast cam. I modified it for the HVX then further modified it for the GH1. With quick releases I can swap both cams on and off between the tripod and stabilizer.
I bought the GH1 confident that I will trade the HVX for the AF100 eventually. I got a great deal on the GH1 and will be able to use all the GH1 M4/3 glass on the AF . I'm sure I will keep the GH1 (if it is still alive and kicking) for the same reason I use it now. High quality video in a totally undercover mini pkg.
Remember...invest in glass not camera bodies! This is the where the revolution begins. Before you could not really apply this concept to video cameras. The GH1 body is a no brainer it is so cheap!
Cheers and good luck!
