I'm thinkng of purchasing a Sony 18-200mm PZ to use on my FS5. I do a fair amount of run-and-gun, most of it outside. Although I have the 18-105mm kit lens it isn't giving me the reach I need plus I can personally see the degradation in quality as you push further into the clear image zoom in 1080. So that's why I'm looking at the 18-200mm PZ.
So far I've picked up the powered zoom is very slow (unless using manual) and there's an obvious light loss when zooming (ie f3.5 - f6.3). I also know there is a temporary shift in focus when you change zoom direction. But given my intended usage is there anything else I should be aware of?
Something I picked up is this lens has OSS 'Active Mode', which 'seems' to go above and beyond standard Sony OSS. Can anyone gve me an idea of whether this really does make any real world difference or it's just marketing spin?
On this note will OSS 'Active Mode' definitely work with the FS5, ie it's not body specific?
Also with this lens can a variable zoom be achieved via the rocker zoom on the FS5's smart grip? Thus if you press harder on the rocker the speed of the zoom will change. If so is this in any way affected by the position of the H M L switch on the lens?
Finally will the FS5's face detection work with this lens?
