If we can change region of interest then CinemaScope format might be more practical regarding datarate (should be less than comparable 1080p). DCI spec for 2k cinemaScope (2.39:1) is 2048 x 858. If windowing height needs to be divisible by 16, the frame could be 2048 x 864 (just needs 6 pixel crop to height in post). Not sure how close this is to reality -- didn't NURBS shoot a MJPEG wide frame several weeks ago, though may have only lasted a few seconds before card error.
I agree. I do that all the time. It would be nice if we could get 2.35 or 2.40 guidelines on the LCD though. I'll through that in the request thread.
Principially it works (in Mpeg, res. 2048 x 864, qual. 384/330/300/276) - I got quite some "card speed" messages with recording braking down (filming with a Transcend class 10 16GB card), esp. when filming with normal DoF - but this is not so dramatic to me, since I use it for free, creative work and I ilke shallow DoF. This is also not a big problem, since usually it breaks down immediately - of if not, I can film for minutes without a problem. So all I have to do, is delete the 1 sec. clips from time to time...the frame could be 2048 x 864 (just needs 6 pixel crop to height in post). Not sure how close this is to reality -- didn't NURBS shoot a MJPEG wide frame several weeks ago, though may have only lasted a few seconds before card error.
Your suspicions are correct, I did some experiments with MJPEG frame size at an earlier point and it became apparent that the anamorphic squeeze did nothing but degrade the image quality.The problem though, as I suspected, it's just 16:9 material squeezed vertically (instead of horizontally, like the way it is, when you use these "1440x1920"Mpeg settings).
Ok, that's new to me - I'm gonna watch it closer when I'm editing the stuff next time... So you mean also regarding 1440x1080 / 1280x1080? Because I thought, everybody was quite enthusiastic regarding these modes?I observed that the GH1 did not produce a technically correct anamorphic image, and the required stretch was not the same as the patched dimensions that I chose.
