No, thats not a pad and the audio will distort no matter if it is set to -50dB or -60dB when/if the signal is hot enough. That problem is solved with a pad that one can adjust the incoming signal with -10dB. Sometimes -20dB is necessary, and in extreme cases even -30dB.the panasonic cameras do basically have a -10dB pad right? I mean you can select -50dB or -60dB sensitivity in the recording settings, so isn't that an in camera -10dB pad?
