F35: Any way to find the cameras IP address w/o access to the menu?
pounge
Hey everyone, looks like the F35 I just got has the menus locked out of the SDI outputs/VF 1 & 2. Is there a way to find the IP address of the camera without menu access? I have a Sony BW EVF but it doesn't seem to display the menu, only showing picture with a "LUT" in the top left corner.
I've tried the default IP with no luck and the previous owner had never connected to the camera so no help there.
If finding the IP address is impossible, is there a button combo or hidden pin switch somewhere that'll reset the camera to factory default? The viewfinder I have is a Sony HDVF-20A but I think the VF display settings were changed as well since all i'm seeing is the burnt in "LUT" top left.
see about doing a factory reset.
you have tried the full menu and service menu?
Holding clicker plus menu is full menu.
Have you tried getting to menu blind? The menu opens on page it was closed on. Hit menu, spin clicker once and click it. See what happens.
tried the full menu and service menu (three buttons up top + clicker wheel then two clicks on menu button) and the most i've gotten was a quick blip on the side panel.
I think pulling the cmos battery from the AT card might reset the camera settings.
I don’t have camera on me until next week but I can figure It out with a camera. If you get a blip on side panel that means you are opening the menu, you just can’t see it. You need someone with a camera to open service menu, figure out the clicks to get to camera reset page and then you can reset camera without seeing the menu.
I must admit I’ve only used ip once, I’m all Mac and PC was all I could get to work. But you should be able to get to ip info on the side panel. Of course this could be disabled too.
One more thing to try is the SD Feed. That should have menu info on it also.
Yeah, might have to go through the service menu blind to reset it. Is the SD feed going through the TEST connection? I might be able to borrow an analog monitor but the BM Video Assist doesn't recognize a source from that connector.
