GH4 Any way to delete the annoying AVCHD text?
CustomerGH4
So yeah, when you change your system frequency to a non native one (in my case from PAL to NTSC) the camera displays a text before recording and also when first time opening the play list. This does not disappear after turning it on and off again. What annoys me is that I don´t even use AVCHD.
"Unable to record AVCHD video. The selected system frequency does not match the AVCHD data on this SD card. Please use another card or change the system frequency."
So yeah, anyway to make the text not pop up everytime I turn on the camera? (Besides changing frequency or entering new SD card of course.)
Well, you have to do what it says. Either change out your SD card, or change the system frequency back to whatever's already been recorded on that card.
With AVCHD, you can only record one system frequency (50Hz or 60Hz) on a card. Once you record that first clip, ALL subsequent clips must be in that same mode. If you change the system frequency, you cannot use that card anymore, you'll have to either reformat it, or use a different card.
That sucks.
The annoyance comes from the fact that I haven´t used AVCHD. I would get it if it would show the text when I turn on AVCHD, but it even shows it with MP4 and MOV.
(Using the NTSC mode for the 30p UHD only.)
But anyway, thanks for the fast reply, mate.
