There are many ways of making a fig rig. I made one out of PVC, heated it up and bent it around one of those 45lb weights. Its the perfect size for that. There are tutorials on youtube, here also I believe, just do a a search. It just depends on what resources and tools you have.
I was referring to the 45lb weight. If it had kind of a concave outter edge it would be much easier to keep the pvc wrapped around it while heating and adjusting.
On A side note though... I screwed a 5lb. weight to the bottom of my rig cuz it seems to make shots a little smoother. Hard to describe what my rig looks like cuz its got kind of a stand at the bottom so I can set it down at anytime. I'd have to post some pictures of it.
you take a long pipe made of metal and put you pvc tube inside.
then you use one or two hot blower at each end.
you can also make some very hot water pass into pvc tube (you just fill it)
