Alright I'm planning on filming in low light. It's the kind of light that makes the surroundings somewhat orange (street lights), and I will have no further lighting available. My idea is to record at 24pa and edit in final cut pro. I'm used to this so I don't need help too much here; however, I would like some detailed settings that you have used to get the best picture. I've noticed the dvx100b is awesome with lighting at 24pa, it's just in low light it looses its sharpness and becomes very grainy. I want to limit this as much as possible. Like I said above, if I could get good settings ex> detail coring, iris, etc... (the whole nine yards) I would be very grateful. I understand playing around on the actual "set" would be best to adjust settings and everyone's opinion varies, but I would just like to hear what you users out there use for low lighting conditions. Forget about adding lighting (I'm too poor), advice for best results using final cut pro would be cool too, the street lights are fairly bright (not pitch black), and yes I must film in 24pa.
side note- I need to figure this out soon and this is why I'm eager about the settings. If I had more time to experiment, like I said I usually film with the aid of extra lighting, then I might be able to figure something out. So pretty much my shortened question is what are your "personal best" settings while shooting low light (please if you could include all settings), and is there a way to reduce the grainy image you get when filming in darker locations in both post and pre-post?
