plasticam
DVXuser Sponsor
I've seen some discussion of mounts that have loosened up and after observing my own
FF unit - it is very clear that if you are using a FF with an FS100 be careful.
If you have Duclosed gears or gears that are fixed directly to barrel there is much less concern.
With gears that have spokes to enlarge the diameter and some sort of nut that stops the rotation from
being 360- watch out.
Two things here. First and worst. When the lock down nut revolves around and reaches the end of rotation
it comes up against a hard stop but if you put any further force on it from that point you are using geared
mechnical force directly against the 4 small screws that hold the mount to the camera chassis. You can see
the entire lens moving trying to chevy the lens right out of it's seat. Just be really careful as this is a consumer
built camera not made for the mechnical strengths surrounding pro gears. These things were made for little rubber
bushings and servo motors. FF unit were designed for Panavision, Mitchell, Arri- ever take one of those apart?
They are like a watchmaker decided to make a tank.
Lastly, when attaching/coupling the gears of the FF to the teeth of the lens- keep it as loose as you can.
Remember that when you lock the gear against the teeth any lateral force you create is transferred back to
the mount.
Just a heads up from a shooter who has seen the insides of plasticams- and not on purpose!
It's a great computer jammed into plastic junk.
the mount.
