Jeff B
Anton Bauer ElipZ 10k Battery Kit
New In Sealed Box
The innovative ElipZ 10k brings unmatched power density to handheld 7.2 volt battery operated cameras. Using the highest-capacity lithium ion cells available, the 75Wh 10k can provide runtimes as much as two to five times that of the consumer OEM batteries supplied with the cameras. On a 10w camera load, the 10k will run over 7 1/2 hours, virtually a full shooting day! State indicator LEDs give a simple and easy-to-understand and constant indication that the battery has usable capacity (Blue) or requires charge (yellow). Constructed of high-impact polycarbonate the ELIPZ 10K innovative under-camera mounting design allows batteries to be easily mounted and released with one hand. A quick release shoe attaches to the camera and the battery attaches directly and securely to the shoe. Lowering the center of gravity of the camera and providing an additional handhold without interfering with the camera operation, the lightweight ElipZ battery actually improves the comfort and handling characteristics of the camera. The appropriate adapter cable connects directly to the camera battery compartment and plugs into the PowerPlug connector on the ElipZ 10K. The ElipZ 10K mounts easily to the EgripZ support, or other camera support using the metal 1/4-20 insert at the bottom of the battery. The unique ElipZ power connector accepts both the camera adapter plug and the ElightZ PowerPlug. The 10k is capable at continuous loads of up to 6 amps - more than enough for a camera and light simultaneously. Includes: ElipZ 10K battery and ElipZ charger. Requires appropriate ELIPZ Cable Adapter for your video camera.
New In Sealed Box
