Sparky874
Hello again! Quick question if you don't mind. I live in PAL land, so what System Frequency should I set my new F5 too when I want to use high frame rates? If I set it to 25 (as I shoot everything in 25 fps progressive) this goes up to 150 fps - but the other frequencies (23.98 - 24 - 29.97 - 59.04) let you shoot up to 180 fps. Is there a best option for which frequency to select for my 25 frames progressive edits - or does it matter at all? Would it be 50? Sorry if this seems like a sillly question, but I've come from a 50 fps base - and that was dropping the resolution to 720! Thanks as ever, Sparky
