Hi,
I am about to get a GH2 and after reading several threads I have decided to get these lenses as a starting kit
What do you think?
- Prime - Voiglander 25mm f/0.95 or Panasonic 25mm f/1.4 Micro four thirds
- Zoom - Lumix 14-45mm
I appreciate your feedback. Thanks
Yeah I'd get some more range in there before plunking down on the Voigtlander. That's no starter lens...
-Noah
-Noah
The non-stabilized version of the Tamron 17-50 ( which is cheaper ) is the one to get, as it has better optical performance. Keep in mind that you will need to buy a Nikon G ---> M4/3 adapter in order to control the aperture of the lens because there is no manual aperture ring. ( I don't think MetaBones makes a G adapter )
Tamron SP AF 17-50mm f/2.8 XR Di II LD IF Lens Review
Is the Voightlander autofocus too?
Actually from what I've read, you need a Nikon F to micro four thirds adapter. Not "G".
thats the one BIG drawback of the GH2 route. as thedingo mentions. if you stray away from the lumix and olympus lenses (even new nikons with an adapter) you lose ALL modern features like AF and IS. if you have a background in old school photojournalism, its not that big a deal. but for some people whove come up using servo zooms and auto features it can be a bit of a shock to suddenly have to trust your eye. and each lens is a little different. it takes a while to train your eye to optimal focus - unless you have an external monitor with focus assist features.keep in mind that autofocus is only possible on Panasonic and some Olympus lenses
but sometimes you just crave autofocus. and not having it as a rule was kind of a buzzkill.
