another f35 test...
Re: another f35 test...
would this work on auto focus? Also how much dose your f35 setup cost? Is it spinning glass or static? Nice DOF. Thanks firre..
This looks so much better than the first footage you posted...what's different this time around?
looks great. i even love that it doesnt stay in focus..somethin kinda cool and arty about it.
is that static grain the ground glass or the compression? i feel like im seeing the ground glass but not sure...sweet lookin stuff..makes me want one.
My guess is the ground glass- same as your Rich. I've seen a lot of static adapter footage and this has the same grain.
Looks great. What kind of lens are you using? I'd love to see a photo of the rig.
This is static version dof mochine. There is still visible grain of ground glass. This movie has 360x288 and is compressed in sorenson. This time i grit closeup+4 lens so my setup looks like this:
ground glass: +4 close up, reversed, flatted and grinded one side.
Grinding i made by my own with 1000 grit powder.
Dvx: Focus:31% Zoom:71
Amahp: this don't work on auto focus. I'm use manual 35mm Canon FD lenses:
50mm f1.4
28-55mm f3.5
45-105mm f3.5
60-300mm f3.8-f5.6
On video that i share i use only one lens[ 50mm ]
On this monday we wil shoot our first pictures with this setup to 10 short film "rose".
was your ground glass spinning?
Also, could you post some pics of your setup
your footage looked really good
Looks awesome, firre! I'm building an almost identical setup -- I'm just waiting for my +10 macro to arrive. I did use a 52mm GG and PLCX lens, so I had a bit of an engineering problem going from the 52mm tubing to the FD mount, but I solved that today. Now, I am most impatient for the macro lens to arrive! Your footage makes me very excited. Good luck with your shoot.
Fox
Is there a DIY floating around on how to put together an adaptor like this? Something easy and straightforward.?
It cost me about 300$.
I'm not using OptoSigma 1500 ground glass. I use homemade ground glass [1000grit] from +4 closeup.
I'd like to make better ground glass in optical shop....
That is one of the best things i have seen. I would love to see a picture of the rig. How much did it cost to asemble?
