Anamorphic bending of image?
mickeloaf
With Anamorphic guide in hand I've been playing with the adapter and have noticed a slight bending of straight edges on my test material (kind of like a bend at the top and bottom of the edge, kinda like a fisheye but not so exagerated).  I didn't notice this with squeeze mode.
Am I doing something wrong here, or is this just normal behavior when using the adapter?  I didn't catch any mention of this anywhere, so just wondering if it's just me or what..
Re: Anamorphic bending of image?
Sounds like normal wide angle behavior to me (the anamorphic is wide angle in one axis). It's absolutely normal distortion - no worries :) (unless it bothers you a lot!).
Thanks for the response Shaw. Yeah i wasn't sure if maybe it was an issue of the zoom, or if i put that thing on slightly crooked. I figured it would stretch the image on the horizontal, but didn't think it would cause a bending of a straight edge (for example the edge of a fridge or the corner of a wall).
You're seeing barrel distortion. It's happening, as Shaw said, because the anamorphic is actually a wide-angle adapter as well (but only on one axis, the horizontal). Lenses tend to get barrel distortion the wider they get, and barrel distortion taken to the extreme becomes a fisheye effect. The DVX exhibits barrel distortion in and of itself, but very mildly... wide-angle adapters (and the anamorphic) exaggerate the effect.
How do people compensate for that? My guess is that you try to compensate by setting up shot's that don't have lots of vertical straight edges. A person wouldn't even notice if it wasn't for the reference lines in the scene.
Thanks for the feedback guys!
That's one way; the other way is to not zoom out so far. I think by about Z10 most of the barrel distortion is minimized.
