I'm thinking about buying an HVX-200, but I'm curious about the quality of the analog outputs. If I were to shoot directly to HD-D5 via the AJA HD10A converter, would I get a better picture? Because I would avoid additional compression artifacts that would be introduced when going to P2 or external firewire (which both utilize the DVCPROHD codec).
I realize that the signal would go through an additional A to D conversion, and the HD-D5 has a very gentle 4:1 compression. But, in theory, there should be fewer compression artifacts.
Normally, the compression artifacts of DVCPROHD would not be a big issue. But, I'm going to be shooting a lot of green screen for compositing. And I know from experience that the compression in HDCAM and DV can be very hard to deal with.
Thanks,
Paul
Thanks,
Paul
