BobDiaz
The Professor
In a perfect world, we would all shoot green screen videos with 4:4:4 color. Still, the world is not perfect and we must deal with the realities of cost. Yet, after looking at the green screen images up close, the imperfections do show under magnification, but are really small when shown on the screen.
What follows is a 10x magnification from sections of the above images. Looking at the DV25 image, you can clearly see the problem created by 4:1:1 color. While the limits in the color are in a horizontal direction, the errors appear in a vertical direction.
Without question, the DVCPRO image has a much cleaner edge to it. At high magnification you can see some imperfections, BUT at a normal viewing distance, it will look very good or in non-technical terms, it kicks a**!!!
The 720p image surprised me, because it looked so good. This image made me believe that I was looking at a native 960x720 CCD, because I can't spot any glitch appearing every 4 scan lines. I reasoned that IF the CCD was 960x540, every 4 scan lines there should be a minor imperfection. Well, know we know that my logic was flawed and a 960x540 Native CCD DOES produce a clean 720p image.
Like the DVCPRO50 image, you can see the green appear along the edge every 2 columns. I do see a slight vertical error that occurs, but because it is vertical, it tells me that this is the limit in the horizontal color resolution.
The one mystery that I can NOT answer is why there is a vertical glitch that appears every 2,4,2,4,2,4,... pixels in 1080 mode. The glitch appears as vertical lines, so this has something to do with limits in the horizontal color resolution. This is odd, because with 1280x1080 at 4:2:2, we only need 640 color samples and 960 color samples is more than enough.
Could this somehow be connected to 1920 pixels being converted to 1280 and later on back to 1920? If so, 3 pixels would be converted to 2 pixels and later on back to 3 pixels. This might create a 6 pixel pattern that I see. Then again, it could be something else...
For comparison sake, here's a green screen shot from the Canon. The file name says it was shot in 1080i. I wish I had a shot taken in 24F or 30F mode, but this is what I have:
You can see the glitches appear in the horizontal direction. This is due to the lack of color information in the vertical direction.
CONCLUSION:
There's no question that the DVCPRO50 is really clean for green screen video and the 720p footage offers a reasonably clean edge too. I wish I had more 1080 green screen stills to look at for comparison. It does bug me that I can't fully explain the funny 4, 2, 4, 2... glitch pattern and I don't know if it's normal or just something that only appears in that one green screen clip. Oh well, another mystery in life...
Bob Diaz
CONCLUSION:
Bob Diaz
