wgzn
ok, lets narrow things down:
what version of FCP are you running?
1. it would appear from your posts that you have successfully transferred the footage from your P2 card to your computer, is this correct?
if so. you SHOULD have a folder on your computer somewhere that has BOTH the CONTENTS folder and LASTCLIP.TXT file.
what is that folders name? it should have only abc_ABC_123 in it's name. no special characters and use UNDERSCORES rather than spaces
2. power down then disconnect your camera from the computer. (this step isnt crucial. it just removes any confusion as to where FCP goes to find footage)
FYI NEVER connect or disconnect your camera from the computer while the camera is on. always power it down before inserting/removing cables.
3. depending on your FCP version...
if its older that 5, im not sure it supports P2 at all.
if its version 5 go to file >import > P2
if its version 6 or 7 go to file > log and transfer
4. in the import / transfer window. there will be a little folder icon in the upper left (or a + sign somewhere near the top, FCP5). click that and navigate to the folder that you created that has the CONTENTS and LASTCLIP.TXT. navigate to that FOLDER and click Open.
5. a list of thumbnails should appear in the window, yes?
here you can do a number of things:
you can watch the clips
set in and out on the clips
select what tracks to capture
rename clips
add selected or all clips into FCP
you can either select all, command click to just get the ones you want, or just do one at a time. whatever suits your needs.
once youve done this, click the "Add Selection to Queue" button. its at the lower right of the thumbnail list
is this where the red exclamation points appear?
if so. a couple of things may be happening:
1. one or more of your files may be corrupt. if the footage is still on your p2 card. put the card back in the camera. do a repair clip procedure on the card and repeat the whole process
2. did you shoot multiple cards? if your footage spanned multiple cards, you often need to have both cards copied to the computer and added in the log and transfer window for them to show up successfully.
if you DID shoot multiple cards, have you transferred both cards CORRECTLY? you need to create a NEW folder for every card you shoot. my fool-proof folder structure this is:
JOB_NAME
--- SOURCE_MM_DD_YYY
------ P2
--------- CARD_01
------------ CONTENTS
------------ LASTCLIP.TXT
--------- CARD_02
--------- CARD_03
and so on for each card i fill on a given shooting day
are we all on the same page here? if you indeed have NOT successfully copied the footage from your card to a folder on your computer. let us know and we can backup and take care of that...
rename clips
JOB_NAME
------ P2
--------- CARD_01
--------- CARD_02
--------- CARD_03
