EDV Well-known member Aug 30, 2013 #1 Original Panasonic CGA D54s 5400m Ah Replacement battery 1 6000m Ah Replacement battery 2 6600m Ah What is going on here? Is higher Ah good or bad? Also...are these batteries universal? ( can be used by both 50hz and 60hz Panasonic cameras ) Thanks in advance!
P Paul F Veteran Aug 30, 2013 #2 Higher is good. It means it will last longer. BUT, I wouldn't trust that the ratings are accurate. There are no standards for rating a battery's amp/hour (Ah) capacity. 50/60hz doesn't matter.
