cowpunk52
Some quotes from Alan Roberts on a "different site"
"Chaps, I've completed tests on a 305, and it's rather lovely. It preforms dramatically better than a 1"/3 camera should do. The test was for an independent production (not European) and Canon, with the BBC taking a back seat for a change. So the settings doc does not carry the BBC's imprint. Nevertheless, the tests and reporting procedure are exactly as for any other test."
"I think this camera raises the issue of whether 1"/3 is ok for broadcast, certainly it performs as well as, if not better than at least 2 1"/2 cameras that are approved by the BBC, and doesn't need external recording to achieve that performance. And as for 13 user buttons, well ....."
"the 305 appears to out-perform the EX in all respects, if only marginally, which is entirely the wrong way round, it shouldn't be so,. Clearly Canon have been doing some very clever things behind the scenes for a while, some of which I still don't understand."
"the XF appears to be a little more sensitive than the EX, and to have slightly better noise performance, and the range of usable aperture values is about the same."
"this camera goes to F/1.6 and is good nearly to F/8, which is significantly better than it should be, the lens is much better than I'd expected."
"this camera should force a change of broadcasters' rules. I think that may already have happened in the BBC; although the tests were independent of the BBC this time, they have the report just like anyone else."
