Alan Roberts BBC report on the AF101
Status
Not open for further replies.
olof
DVXuser Sponsor
http://thebrownings.name/WHP034/pdf/WHP034-ADD66_rev_2_Panasonic_AF101.pdf
Conclusion
This camera does not perform particularly well at HD. Clean resolution is limited to about 1210x680 by the presence of high-amplitude spatial aliasing. This is a little disappointing from a camera with a large-format sensor, and indicates that optical low-pass filtering is either absent or inadequate, and that the scaling from the resolution of the sensor down to 1920x1080 has not been done in the best way.
Noise levels are rather high, even though the pixel size is that of a conventional 3 sensor 1⁄2” camera. Sensitivity is also similar to that of a 1⁄2” camera.
If this camera is to be used for HDTV shooting, then it should be clearly understood that it’s only advantage over smaller-format cameras is the smaller depth of field. However, to achieve a smaller depth of field in this camera, relative to, say, a 1⁄2” camera, then the lens must be opened by at least 1.5 stops; using an F/2.8 lens on this camera, wide open, will give the same depth of field as on a 1⁄2” camera with a lens opened to F/1.6. This camera will not necessarily always deliver short depth of field, large aperture lenses must be used to achieve that.
Status
