Aja lhe for leopard drivers is out!!!
Finally the leopard drivers is out I thought....
When i try to start fcp, I get a message that say "minimum system checks", and complain on my system. But i have a macpro 8 core, 4g ram wich worked nice until I installed leopard...
After I upgraded (mm "up"grade I still not sure of...) then I got the same minimum requirements message as I get now due to the aja v.4 drivers didn't support leopard)
But when i install the aja v.5.0 drivers it start to give this message again.
..I have reinstalled fcp and aja lhe..but same issue. Any ideas?
If i delete Ajas drivers i get the message:
External A/V
Aja Kona 720p25 8 bit DVCProHD (1280 x 720)
Your system configruation may have changed, or you deck/camera may be turned off.
Please check your connections and click "Check Again", or click "continue" to set an external device selection to none.
Same as I get right after installing Leopard.
I have final cut studio 2
I have got an tip from other forum:
do a CLEAN install of Leopard- not an upgrade - that's right - wipe off your hard drive, and fully reinstall the OS (not an upgrade) - a pain in the ass - absolutely - then load in FCP, and launch it, then load your AJA drivers. Then you will be in business.
Do you have the time to do this - NO
Do you have to do this - YES.
I hope anybody here have another idea, Yes i did the upgrade not clean install of leopard.
