AJ-PCD2 Please Help
Johnny Bueno
I just bought a AJ-PCD2 and I just tried to use it. I attached it to my Macbook Pro. I right protected my card, inserted it in the card reader. The P2 card mounted and appeared on the desktop as "NO NAME". I opened FCP and pulled up an existing project and I clicked "FILE" then "Log and Transfer". Nothing happened. The log and transfer window came up but the video clips did not. Then I realized i needed to instal the driver for the PCD2 from the disc that came with it. So i did. It installed perfectly fine. BUT the same thing happened still. I pulled up the project, went to log and transfer and the clips did not pop up. What is wrong? Am I missing something? Any help is greatly appreciated. Thank You.
Johnny
EDIT: I am using a Belkin USB Hub to plug into on of the 2 usb ports on my macbook pro. It gives me 3 more usb ports so that I can connect my hard drive and the PCD2 since the PCD2 needs to use 2 usb cords.
Nevermind guys. Problem solved. You don't even want to know what happened lol. It was my stupid mistake. Thanks again though
