NeedCreative
Interesting, looking at Sony's site I noticed the brochure was revised from March to May. The workflow page on the new brochure is totally different and notes the following:
"HDMI 1.4 Output with Embedded Time code for 4:2:2 or RGB 4:4:4 Uncompressed Signal Output When shooting, the NEX-FS100U provides HDMI 4:2:2 or RGB 4:4:4 uncompressed output with an embedded SMPTE Time code and embedded 2-3 pull-down markers for recording on external disc recorders.
Note: Embedding 2-3 pull-down markers enables material originally recorded at 24p and converted to 60i to be recognized once more as 24p in the HDMI output signal."
http://ws.sel.sony.com/PIPWebServic...-261029/original/nexfs100u_brochure_v2497.pdf
Now I don't know if 4:2:2 is an option? I do know RGB 4:4:4 is in the HDMI spec. So it looks like we can get 4:4:4 uncompressed out of the HDMI of this camera. (Albeit 8-bit.) Even the F3 doesn't output 4:4:4 out of the box - that's an addon that will cost $$. (It does output 10 bit 4:2:0 though).
Other changes: Sony now directly compares it's sensor to the micro 4/3rds instead of just a "conventional camcorder" as well as a "full frame DSLR camera" for sensitivity instead of just a DSLR. They note there are 3 1/4 mounts on the top of the camera now (there's one under the hot shoe and that is what the handle mounts into, not the hot shoe itself). They also note the addition of a hard side case as an option and removed the soft-sided cases listed in accessories.
Nothing else changed in the brochure, and their site still indicates 4:2:0 but the brochure linked from it now says 4:4:4.
