Mike is totally correct in saying that coring can produce awful effects, whatever the camera. In general, it's best turned well down.Coring, on the other hand, smooths out the image, which can help with noise in general... but at the expense, if it's too high, of creating a smeared or a soft focus look.
detail coring 0, master detail 0, gain 0db other settings full manual
this camera is noise generator:
https://www.dropbox.com/s/43eex7nzdpj8313/01100022.MP4?dl=0
when the light decreases, the color is very reduced, compared to other ca
meras
https://www.dropbox.com/home?preview=01100027.MP4
I just downloaded this clip and played it. It looks great. There is no obvious noise on it. Where are you seeing "noise, noise noise"?today shot, all ground settings, gain 0dB, balance: local, SCN1, detail level:0, aroma level:0, location: television studio
raw file here:
https://www.dropbox.com/s/dj21f4rt5wjr7qn/01100006.MP4?dl=0
noise, noise, noise
i never use auto-whitebalance, i use the local light balance, and the camera is always in full manual settings.
here is the raw footage:
https://www.dropbox.com/s/75wviq2qi9nv9bi/noise.mp4?dl=0
if you want to watch it you have to download it!
Just downloaded it and played it. It looks great. There is zero objectionable noise on this image. None at all.detail coring 0, master detail 0, gain 0db other settings full manual
This link didn't work for me, I couldn't download this file. It just kept going to the "Log In To DropBox" page.when the light decreases, the color is very reduced, compared to other cameras
As a first approximation, the DVX200 chip is approximately 16 times the area of that used in the AX1 - which should give it a 4 stop advantage over the AX1 if all else was equal.
Apologies if it has been asked and answered. What is the sweet spot iris range on the DVX200 in 4K and in 1080p?
Keep the iris in single digits in 4k/UHD. F/10 or more should be avoided; stay between f/2.8 and f/9.6 for best results.
In HD it doesn't matter, you can use the full iris range.
Whilst agreeing with what he says, I'd probably put the general advice the other way round - take the coring level well down, then set detail level to suit.
How are you viewing this footage? Have you tried playing it back on a 4K or HD monitor? Or are you only viewing it on the computer? Because there's nothing wrong with this footage at all, there's just no objectionable noise at all. There's just the tiniest bit of noise in the jacket, but you'd have to pixel-peep and stare at it to be able to even notice it...
