Barry_Green
Moderator
APS-C and Super35 aren't the same, but APS-C (at least from the Canon) and 35mm cine are exactly the same. Well, almost exactly the same; APS-C Canon is 22.3mm wide, 35mm cine is 22mm wide.I think Ilya Friedman wrote something similar at dvinfo. But this crop factor is comparing the GH1 sensor 16:9 image area to the APS-C chip sizes and Super 35mm image area interchangeably as if they were the same. This is a mistake. They're not.
35mm cine and Super35 are not the same, and shouldn't be stated as if they are the same. "flat" 35mm, which (last time I checked, years ago) the vast majority of films were shot in, is the 1.85:1 extraction of the "academy" aperture on the 35mm film frame. 22mm wide, 12mm tall.
Super35 is used for 4:3 television, or for widescreen productions (2.39:1) when one doesn't want to bother with using anamorphic lenses. It can be cropped down for 16:9 HD, and there's no real reason (for television origination) to not use S35, but it doesn't really give you much of anything over regular35 when used for television anyway.
AND when compared to 35mm cinema film. Not Super35mm, but 35mm cine.It's only when compared to APS-C digital cameras where the 1.18 crop factor would be true
How do you figure? Only those who spent for edge-to-edge Super35 glass will be missing out on what that additional expenditure bought them.So unfortunately those people who have made heavy investments in cinema glass with edge to edge sharpness are not going to be using much of the image benefits that these kind of lenses can provide.
