SOLD AG-AF100 Case: Panasonic PKB-275PV Portabrace Hard Case and soft interior case $499
Status
Not open for further replies.
delete
delete
NEW Panasonic PKB-275PV Portabrace Hard Case and removable soft interior case with divider kit
Works great with the Panasonic AG-AF100 and other HDSLR based cameras.
$499 with Free Shipping
http://shop.texasmediasystems.com/Panasonic-PKB-275PV-Portabrace-Hard-Case-and-removable-soft-interior-case-with-divider-kit_p_4485.html#
Hard Case:
The hard cases shell is airtight and watertight. It has an auto-pressure relief valve, easy-open latches, and a comfortable hand grip. Portabrace Hard Cases are constructed with a high-performance, unbreakable hard-resin material reinforced at the corners.
Weight:
20.15 lb / 9.14 kg
Interior:
L - 21.25" / 53.98cm
W - 18" / 45.72cm
H - 9.5" / 24.13cm
Exterior:
L - 24.5" / 62.23cm
W - 22" / 55.88cm
H - 11" / 27.94cm
Soft Removable Case:
1000-denier Cordura® material with thick padded, semi-rigid walls. Padded interior divider kit includes: (3) padded lens cups, (1) 6"x6" padded pouches, 9"x9" padded pouch, (1) fleece and foam bead camera pillow, (1) foam camera-stabilizer block, and bendable dividers. Add the PKB-HL Backpack Harness option to carry the removable case as a comfortable backpack.
Weight:
1.5 lb / 0.68 kg
Interior:
L - 17.5" / 44.45cm
W - 14.5" / 36.83cm
H - 8.5" / 21.59cm
Exterior:
L - 21" / 53.34cm
W - 17" / 43.18cm
H - 9.5" / 24.13cm
Status
