I just need to know if it is better than the DVX100b in low light?
Hi Tom
Impressive!!! open iris and 30db is quite incredible for those tiny chips ..OK there is noise there but if I had shot the same with my HMC80 at 24db it would have been a LOT noiser!! I don't see any of the "smear" (spray paint hair effect) that the guys were worried about on low light shots....Despite the huge gain that's still a usable image!!! Meant to ask ...is the scene file setup like the HMC 40 which has just 2 files and you have to power down to change them ?? On the 130/160 it's switch selectable but I wasn't sure if the 90 would keep the old method or you could actually change scene files with the camera on.
The outdoor shots are pristine!!
Chris
The DVX100b is actually pretty good in low light. Much better than the original 100 which I also own. If the AC90 is as good or better than the 100b then I will consider it. Weddings are my bread and butter and low light performance is the number one priority for me. Canon will get my money next year when I finally upgrade unless the AC90 proves that it's as good as the XA10.
None at all. It's AVCHD which FCP-X handles smoothly.
Michael
Working on it.1). Scenery with motion (tilt/pan/zoom).
There is basically NO aliasing. I mean, I tested this thing on The Wringer, recording to an external NanoFlash, and it delivered the best results I've ever seen from any camera I've ever tested on that chart. It's incredibly clean.5) Tests of aliasing where you pan camera right & left on tripod while focused on a vertical bar(s).
Will try with the SteddiePod. In general I don't think it's a good idea to use two stabilizing systems together, as they can end up fighting each other and causing complications.8) I am really curious about with the built in stabilization and how a steadicam type device impacts the footage.
There's no need to test it, it's just a built-in, seamless part of the exposure system. Any time you have an iris smaller than f/2.8, the ND filter will be engaged to some extent or other.12) Is there a way to test the built-in ND? A light on a dimmer?
The DVX100B had a substantial reduction in noise as compared to the prior DVX100A. There were a number of changes from the "A" to the "B"; I did an article on it here at the time.Like Zim, I'm interested in the AC-90's low light performance vs. the DVX100. I have the DVX100A, not B. I didn't realize there was a difference between the A and B on low light performance, as was implied above. I thought the B was made from more environmentally friendly materials but otherwise the same. The 30dB shot, though noticeable noise, was much less noise than the DVX100A at 12dB.
Yeah, that's the wacky thing -- there really isn't much noise at all. Even at 30dB. Unless you crank the detail up a lot; if you set detail to +7 and then 30dB, you'll see noise, but even then, a lot less than other cameras.Where is the noise? There should definitely be noise visible at 30 dB.
