Hey there,
I downloaded a few files of original gh1-footage to test the workflow primarily using after effects but I fail to remove the pulldown. When I use AFX to remove the pulldown I get problems very similar to what is described in this topic: http://www.dvxuser.com/V6/showthread.php?t=171841 Some frames a repeated, on other frames I see seperate fields. But it happens completely random. Even when I jump to another time in the composition an back it’s not the same frame which is messed up but another frame close to it. The problems stay when I export the footage.
I also tried neoscene but this leads to a few other problems. First, I think the cineform codec slows down AFX and provokes instability. Playback of clips is rather fast but simple activities like open menus take longer when neoscene files are imported. I had an early version of the neoscene player installed but removed it because AFX crashed nearly every time at startup. This has become a little better but is still a problem. Furthermore, AFX doesn’t work well with the footage: it recognizes a framerate of 23,9761 and if a proxy for a cineform-element is created, there is a little offset in time which makes compositing impossible. And in general, I hate the idea of loosing quality by recompressing the footage.
Is there another way to remove the pulldown which I could try or has anybody an idea why AFX can’t cope with the gh1-files?
Thanks a lot!
edit: Why have the separations between paragraphs been removed? Strange ...
Thanks a lot!
