kgb
Hey everyone, I've been shooting quite a bit of stuff since I bought the HVX-200 about a month ago. I guess I wanted to get some advice from the vets.
One of the first things I've noticed about the HVX is that it requires a lot of light to get a minimal amount of noise. Is it pretty much a full-iris, little to no gain switch setting that will give you the best results? Also, what are some optimal shutter settings? What is the best one for capture a low light situation?
The camera does swimmingly (to quote Ann Coulter on the peaceful state of Afghanistan) with plenty of light, and the ND filters are excellent.
I just bought a 32" LCD TV, and a direct component connection looks fantastic, even the miniDV footage. Is there any accessory that would allow the HVX-200 to output to HDMI or DVI?
What is the best quality way/program to burn a DVD? Do you output a 10-bit uncompressed Quicktime at 480p?
And finally, is a mattebox the only viable solution for optical in-camera filters? I went down to the camera shop to look at some 85mm, 82mm, 77mm and 72mm filters, and all of them had issues with dust, gridlines on the star filters and diffusion.
:dankk2:
:dankk2:
